iankerry
Message 1 of 6
BT HUB 4 logs
Hi
I am trying to resolve why my network keeps losing connections briefly with the hub - when the blue lights don't seem to be going off.
i went to the log and found this:
IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.0.11:54333 <-->213.123.130.40:54333 [5.71.123.163:29713] ppp0 NAPT)
12:46:06, 08 Oct.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.0.94:52041->132.245.212.98:443 on ppp0)
12:46:02, 08 Oct.(52189.060000) Admin login successful by 192.168.0.94 on HTTP
12:46:01, 08 Oct.IN: ACCEPT [57] Connection closed (Port Forwarding: UDP 192.168.0.11:54333 <-->213.123.130.40:54333 [95.151.95.105:27731] ppp0 NAPT)
12:46:00, 08 Oct.BLOCKED 2 more packets (because of Remote administration)
12:45:59, 08 Oct.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 74.113.232.22->213.123.130.40 on ppp0)
i dont have any port forwarding setup - firewall is default.
any ideas? thanks
5 REPLIES 5
Message 2 of 6
Re: BT HUB 4 logs
if the hub appears to be holding connection are you trying to connect using wireless or wired
iankerry
Message 3 of 6
Re: BT HUB 4 logs
it can be either, but most importantly the 4 computers in the office all have the same issue and are all wired.
Message 4 of 6
Re: BT HUB 4 logs
Are you a business user?
iankerry
Message 5 of 6
Re: BT HUB 4 logs
yes. is that a problem? 🙂
Message 6 of 6
Re: BT HUB 4 logs
This is the BT Residential Customers forum
If you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
as you should get an answer more suited to your configuration.
