Message 1 of 3
BT HUB Event log
Hi,
In my event log I am recieving many of the following lines. Should I be concerned? What action do I need to take in order to fix if necessary.
10:25:10, 14 May.  wl1:IGMP join received for group 226.40.71.93 on interface wl1
10:25:02, 14 May.  eth1:IGMP join received for group 234.81.130.251 on interface eth1
Thanks for any advice.
2 REPLIES 2
Message 2 of 3
Re: BT HUB Event log
No, you needn't be concerned, its your TV box connecting.
Message 3 of 3
Thank you for the quick response ...
