Sinergy
Message 1 of 3
BT Home Hub 3 Slow LAN Home Network Wireless Speed (Under1mbps)
Hi there 🙂
My Home Hub 3 LAN Wireless speed has always been under 1mbps, but I am guessing that isn't the way it is supposed to be? I have looked through all the settings in the Hub Management, but can't see what I should be altering to make it faster. Is there some reason it is limited to that slow speed for my LAN wireless network?
Many thanks.
2 REPLIES 2
Message 2 of 3
Re: BT Home Hub 3 Slow LAN Home Network Wireless Speed (Under1mbps)
can you post stats from your hub 3
From http://192.168.1.254
Settings ->
Advanced Settings >
Broadband >
Connection >
Click "Show Details" Button at the bottom
You can also try the direct link
http://192.168.1.254/index.cgi?active_page=9116
run btspeedtster and when first test completes then run diagnostic test and post results  must be done with ethernet connection not wireless  http://www.speedtest.btwholesale.com/
there is no guaranteed speed for wireless connection
enter phone number and post results  delete number  https://www.btwholesale.com/includes/adsl/main.html
Sinergy
Message 3 of 3
ADSL Line Status Connection information
Line state: Connected
Connection time: 0 day, 03:27:08
Downstream: 2,592 Kbps
Upstream: 448 Kbps
ADSL settings VPI/VCI: 0/38
Type: PPPoA Modulation: G.992.1 Annex A Latency type: Interleaved
Noise margin (Down/Up): 6.5 dB / 15.0 dB
Line attenuation (Down/Up): 60.5 dB / 31.5 dB
Output power (Down/Up): 18.0 dBm / 12.3 dBm
FEC Events (Down/Up): 222493 / 105
CRC Events (Down/Up): 49 / 1 Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): 0 HEC Errors (Down/Up): 197 / 1 Error Seconds (Local/Remote): 0 / 0
Phone Number Test: https://ibb.co/iPTQ4z
I can't do the wired ethernet test due to configuration of PC and hub, sorry. But the wired test shouldn't be relevant anyways to a wireless LAN issue, yes? It seems most of these test results pertain to my connection between the Hub and the exchange, not for my LAN? Many thanks.
