niktrowles
Message 11 of 28
Re: BT Home Hub 3 as a repater?
This has now been sorted thanks to DS. If anyone else needs any help, please feel free to PM me, and I will do my best with my limited knowledge.
Message 12 of 28
I am pleased that DS was able to help you, he has spent a lot of time sorting this out.
Roytaway
Newbie
Message 13 of 28
Thank you. I was able to follow the instructions just fine and my BTHH3 has been active and stable for 3 days. A couple of points that might help others-
Don't expect to see the Broadband light active on the slave hub.
I had to PD/PU the Master Hub to establish a connection.
Just wish I had come across this before purchasing a 3rd Party Repeater that only stays up for an hour at a time!!
Anyway thanks again!
Roytaway
Newbie
Message 14 of 28
vjking
Message 15 of 28
Hi Keith. I have linked a HH3 Type A as a wireless repeater to a HH4. It works really well. Now I'd like to add another HH3 (this time a type B), is the procedure the same? Thanks.
Message 16 of 28
I did not write the original article, but I cannot see why it should not work, provided that you use a different IP address for the additional HH3, assuming you have an unused spare.
As forum member DS says
"Click Home Network, then IP Addresses. Change the IP Address to one not in use.
eg. 192.168.1.245 (NOT the default .254:smileywink:) or one of your choice (192.168.1.**), click apply (ignore any warnings)"
Use a different value for the red stars.
BravoLima
Message 17 of 28
Can i use the HH3 as a wifi extender / repeater through my EE router if i plug it into a powerline adapter with a cross over cable upstairs in my house ?
Message 18 of 28
You would have to ask that on the EE forum, as people here are BT Broadband Customers, and would have no information on the EE router.
Try http://community.ee.co.uk/
BravoLima
Message 19 of 28
Ah thanks.
BravoLima
Message 20 of 28
Surely it's just a case of having the right settings for each of the routers...?
