iqzy
Message 1 of 272
BT Home Hub 4
I know the BT Home Hub 4 should be releasing tomorrow (10th May 2013) but what about us existing customers that have complained time after time about how rubbish HH3 was and craving for a new router, would we get it free without signing up to another 12 month contract?
271 REPLIES 271
Distinguished Guru
Message 2 of 272
Re: BT Home Hub 4
You can buy one for £35
If not, I'll try again 🙂
iqzy
Message 3 of 272
Re: BT Home Hub 4
I have pleaded with BT and have probably had 6 different hubs since renewing my contract in November. If anything should be entitled with a free one considering the problems I've had with them.
NewtronStar
Expert
Message 4 of 272
Re: BT Home Hub 4
Has anyone got a link to the Technical Specifications on the HH4 ?
kenkyle236
Message 5 of 272
Re: BT Home Hub 4
The new BT Hub 4 product specification
Ports and Sockets
• ADSL network interface for BT Broadband
• 1x RJ45 Gigabit WAN interface for BT Infinity
• 4x RJ45 Ethernet LAN ports
• 1x Gigabit Ethernet
• 3x 10/100 Base T Ethernet
• 1x USB 2.0 master socket x1
Buttons
• Wireless: WPS
• Reset (Pinhole)
• Restart
• On/Off power button
LED
• Power
• Wireless
Weight & dimensions
• 301 (gms)
• 116 high x 236 wide x 31 deep (mm)
Wireless
• Dual band concurrent wireless
• 2.4GHz: 802.11n dual-stream 2x2 MIMO. Back compatible with 802.11 b/g
• 5GHz: 802.11n dual-stream 2x2 MIMO. Back compatible with 802.11a
• WPS wireless connection
• Smart Wireless – automated channel selection in 2.4 & 5GHz
• Wireless channel operation
• 2.4GHz: 20MHz (default), 40MHz supported
• 5GHz: 40MHz (default), 20MHz supported
• Up to 64 simultaneous wireless users supported
Wireless encryption
• 2.4GHz: WPA & WPA2 (default), WPA, WPA2 and WEP 64/40
• 5GHz: WPA2
Wireless Transmission speed
• 2.4GHz wireless: up to 300Mbps
• 5 GHz wireless: up to 300Mbps
• Up to 150 Mbps (20MHz)
• Up to 300 Mbps (40MHz)
Power consumption
• Latest intelligent power management; hub functions are monitored and individually put into power save mode when not in use.
Other features
• Packaging designed to fit through typical UK letter box
• Smart set up – new CD-less installation
• Support for BT Wifi
• Packaging is 100 per cent recycled card with non-petrochemical inks
Message 6 of 272
Re: BT Home Hub 4
Only one Gigabit port, same as the HH3, pathetic.
Distinguished Guru
Message 7 of 272
Re: BT Home Hub 4
The WAN port is also Gb
Message 8 of 272
Re: BT Home Hub 4
Yeah, but only one output is Gigabit. And before somebody says you couldn't max out more than one, I have 330Mbps FTTP Smiley Happy
Distinguished Guru
Message 9 of 272
Re: BT Home Hub 4
Does your modem have a Gigabit port?
Message 10 of 272
Re: BT Home Hub 4
Doesn't matter I have a gigabit switch installed in my network, would have been nice to see a significant router upgrade. Ive been thinking of getting a Asus rt-n66u or Netgear N900 for a while anyway.
