zen15676
Message 1 of 5
BT Home Hub 5 - Lost the card with the WEP Code on it - how do I get the WEP??
Hi,
I have managed to lose the little card at the back of my BT Home Hub 5 that had the SSID & WEP code.  The WiFi is working fine but I want to add a new device.
How to I go about getting the WEP Code?
Thanks in advance
4 REPLIES 4
Message 2 of 5
Re: BT Home Hub 5 - Lost the card with the WEP Code on it - how do I get the WEP??
Can you enter hub manager 192.168.1.254 then enter admin password tgen go to wireless then you should see tge wireless password
kenkyle236
Message 3 of 5
The information for the WiFi password and others can be found at the bottom of the Hub
Tags (1)
albro
Newbie
Message 4 of 5
Re: BT Home Hub 5 - Lost the card with the (Wifi key) WEP Code on it - how do I get the WEP??
To access your wifi key (password) for BT Home Hub 5.
- open new web browser
- enter 192.168.1.254 to acces 'Home Hub Manager'
- acces the header 'Advanced Settings'
- enter your 'admin password' you need this without it you can't go any further
- in advanced settings acces 'Continue to advanced settings'
- on header open 'Wireless'
- Wireless key should be visible on new screen
Message 5 of 5
Hopefully the OP has sorted it out, you are replying to a 2 and half year old post.
There is also the slight flaw that the admin password is on the same (missing) card as the wireless passkey.
