Message 11 of 13
Re: BT Home Hub 5 (Type A)-Incorrect password when connecting Wi-Fi, but the password has been uncha
Unless you have made changes to the default settings such as port forwarding or WiFi names, nothing will be lost.
Message 12 of 13
Assume this is a work around rather than a fix? How often will we need to reset the hub?
Message 13 of 13
As we use 3 whole home WiFi discs do we reset the whole lot or just the hub? As we access WiFi via the discs not the hub? Thanks
