Message 21 of 53
Re: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.264
rouge3, my 5ghz is working again and the router has settled down, not sure if it was anything I did.
Moderator
Moderator
Message 22 of 53
Hi @rogue3  sorry you are experiencing a problem with the 5ghz in the last few days.  I've sent you a Private message explaining how you can contact the forum moderation team and we will be happy to help you get this fixed.
Check here: https://community.bt.com/t5/notes/privatenotespage
@NigelMcD  thanks for the update and glad to hear all is now ok for you.
Cheers
John
Message 23 of 53
My down speeds have dropped by 5M on the download down to 44M. Mind you the  NoiseMargin has slipped up to 9dB since the update, prior to that it was 7dB and speeds were about 49M. The NM flutter though looks a lot better now according to my router stats monitor.
Still getting the TR069 daily @  ~20:00 but they seem to be a shorter than that long one on the 5th. Since hte 5th the tro's do not seem to change the NM from 9dB.
At 9dB things seem to be more stable line wise but I guess the trade off is slightly slower speed. I'd rather it be stable than worry about 5M difference. A year ago I was getting 51M but it was up and down like a yoyo some days. Was quite annoying when it decided to TRO in the day time now it seems to be at about 8pm most days and does not stumble like it used to.
Message 24 of 53
4.7.5.1.83.8.264 Software Update Broken 5GHz SSID
Hi everyone. I am new to this forum so posting my first question. As of 1st March 2019 , my HH5 was updated with software version 4.7.5.1.83.8.264, and now none of my devices will connect to 5GHz SSID. 2.4GHz works perfectly. These decives comprise iPhone, iPad, and a high sepc almost new Dell Laptop. Every time I try to connect, I get the message 'incorrect password ' To help with any replies: My HH5 has been working perfectly for the last two years with the following set up: 2.4GHz and 5GHz bands seperated (unsynced), 2.4GHz defaulted to CH1, 5GHz defaulted to CH36. My next door neighbour is on CH13 and CH44 respectively. I have hard reset the router twice (button on back pressed for 20 sec etc) so I really dont know what to do. Does anyone from BT read these posts? I will not call Customer Support becasue all they will do is tell me to reset etc. I am loath to buy a third party router at this stage as I feel this is a result of something that BT has done with this latest software update. Any help will be appreciated before I go to PC World!!
Message 25 of 53
Re: 4.7.5.1.83.8.264 Software Update Broken 5GHz SSID
phone CS like other do and get a replacement just be insistent - others seem to get a replacement without problems   It is free provided you are still in a fixed term contract
Message 26 of 53
Hi imjolly. Many thanks for your reply. Will do...........
Moderator
Moderator
Message 27 of 53
Hi @Niels_T  Sorry you are experiencing a problem with the 5ghz connection on your hub. We will be happy to help you with this issue. I've sent you a Private message explaining how you can contact the forum moderation team.
cheers
John
Message 28 of 53
4.7.5.1.83.8.264 Software Update info
Just a bit of info and what worked for me, after the update to the HH5 I have had really slow wifi across all devices, ipads, android, macs etc, wired connection to the bt uhd box was fine 50mb+ as usual but wifi to everything else was 10 -15mb max, I did a complete factory reset of the HH5 and then turned off smart set up and split 2.4 and 5ghz as per instructions and everything is back to normal 50mb + on wifi on all devices.
Message 29 of 53
@Niels_T
I do think they are looking into it. I've had phonecalls from BT to get information over the issue. May take some time though..
Message 30 of 53
Many thanks. Have had a mail from the moderator so hopeful that issue will be sorted for all of us!
