Shaptor
Message 1 of 1
BT Home Hub 5 blocked access to Google docs for 24 hours 16 May 2020
My Home Hub 5, for no apparent reason, blocked access to Google docs.  No other web sites I regularly use were affected. About 24 hours later the block was released and everything began to work as normal. Again, for no apparent reason. Is this a fault with the Home Hub or a network issue?
