Message 11 of 20
Re: BT Home Hub 5 - consistently dropping connection
NO isp will guarantee wireless coverage or reliability due to too many external interference sources and the device is not mentioned in the T & C's
Sephiroth
Message 12 of 20
Obviously. But then they shouldn't extol the fictitious ability (by your argument) of the HH5 to maintain a wireless connection. The customer relies on the advertisement statement.
Seph
My advice is at your risk.
Message 13 of 20
you could also say that about other router manufacturers as well and some off their claims
Sephiroth
Message 14 of 20
But we are discussing BT & the HH5, not other ISPs. I am not aware of any other ISP campaign that goes on about WiFi in the way tha BT are doing.
Seph
derek918
Message 15 of 20
Totally agree with you, HH5 being heavily promoted on TV now as "the most reliable wireless connection ever" also bt.com/homehub5 - "The new BT Home Hub, Our Most Reliable Wireless signal!". This is 1 hour after mine has dropped it's connection again with no walls in the way and directly in front of me and within 10ft of my laptop.
teakbank12
Message 16 of 20
I was actually ordering shopping online earlier on the wired pc next to the hub which sits next to main feed box (all other internal wiring was disconnected).
I gave up after an hour of disconnections & wife said you'd be easier driving twenty miles to shop than using that piece if junk!!
I am now using my 3 dongle which i pay monthly for & it's performing better than Infinity!!
I would get rid of broadband & landline entirely if it wasn't for Sky downloads i have.
teakbank12
Message 17 of 20
Forgot to add i'm sitting ten feet from hub using my tablet via wifi, hardly live in a mansion 🙂
Sephiroth
Message 18 of 20
Seriously, if it's the same after the engineers have done their bit, move to a modem + router system as I've described.
Seph
Message 19 of 20
While you should not have to do this, my advice would be to buy either a decent VDSLmodem/router or an Openreach modem and a decent wireless router and after having fitted which ever one you buy see how far you can throw the Homehub 5.
Which ever route you go down it will cost you about £70 and provided there is not a fault on your line, it will totally transform your Internet experience and you will no longer be subjected to BT pushing software updates that you don't want or any of the other problems associated with the Homehub 5.
Sephiroth
Message 20 of 20
Spot on.
Seph
