RichWard986
Newbie
Message 1 of 4
BT Home Hub network not showing on wifi, but can connect to BTwifi-with-FON
Hi,
For 3 days now our HomeHub5 home network hasn't been appearing on the wifi list, this is for all devices in the house.
I have followed all the FAQ's, turned the hub off, disconnected and reconnected and likewise for the laptop.
The "BTWifi-with-FON" is still showing, I know this is from our router, as I have switched the power off and it also disappears.
Any help on how to get my home network to reappear greatly appreciated.
3 REPLIES 3
Message 2 of 4
Re: BT Home Hub network not showing on wifi, but can connect to BTwifi-with-FON
Do the devices that were connected to it before the SSid (name) disappeared still connect to it and are able to use the Internet ?
Try a factory reset of the Homehub by pressing a pin into the recess button on the rear for about 20 seconds. This can often sort out problems.
RichWard986
Newbie
Message 3 of 4
Perfect! thanks, the factory reset button has resolved the problem.
Moderator
Moderator
Message 4 of 4
Hi @RichWard986 ,
Thank you for posting back and letting us know that's been fixed by the factory reset.
Cheers
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
