starship
Message 1 of 2
BT Hub 6 with wifi discs ?
I am thinking of going over to the triple wifi discs.
Would i be able to use these with my BT hub 6 ?
Thank you.
1 REPLY 1
Message 2 of 2
Re: BT Hub 6 with wifi discs ?
@starship
If you mean the white whole home discs, yes you can use them with a home hub 6.
You cannot mix them with any other types of discs.
