Message 1 of 6
BT Hub Manager
Hello,
Currently, anyone who is connected to my home WiFi can go to the BT Hub Manager and see the basic information (obviously they need a password to be able to change settings etc).
Is there anyway of disabling any access without putting a password in?
Thanks.
5 REPLIES 5
Message 2 of 6
Re: BT Hub Manager
No
Message 3 of 6
Re: BT Hub Manager
Shame, thanks for replying though.
Message 4 of 6
Re: BT Hub Manager
None of the information visible by default is security sensitive.
What is a bigger issue, in my opinion, is that there is no way to log out after you have put the password in.  You have to wait for it to time out, leaving a window of vulnerability that really should not exist today, even in home grade equipment.
Message 5 of 6
Re: BT Hub Manager
The 'window of vulnerability' is
(a) Very short, the login times out after a few seconds of inactivity.
(b) The login is only valid on the device that logged in, not any other devices.
Hardly a major concern!!
Message 6 of 6
Re: BT Hub Manager
a)  Usually,…I’ve known it to be a lot longer than a “few seconds” at times.
b)  A fair point.  I’ve never tried to access it from a second device, so I’ll take your work for it.
