Tanyab
Message 1 of 7
BT Hub not connecting to broadband
My activation day was on the 13th. I had 2 emails sent to me and a text saying my broadband was ready, but the BT Hub I have connected flashes a purple light, indicating that the broadband wire is not connected when it clearly is. When I go to the BT Smart Hub Manager it says that the Broadband connection status is "Disconnected". My Sky Hub was working just fine right before the activation. I've performed every check, rewired everything, factory reset and still after over 6 hours of struggling nothing has changed. Does anyone have an idea of what this could be? Faulty hub, or has BT just not activated my broadband?
6 REPLIES 6
Keith_Beddoe
Message 2 of 7
Re: BT Hub not connecting to broadband
Is your phone working?
Tanyab
Message 3 of 7
We don't have a phone but the Sky Hub was working just fine earlier.
imjolly
Message 4 of 7
first priority is check you have a dial tone  if no tone then no broadband
a £5 investment on a cheap corded phone can save you callout Fee of £129.99 in the future
Keith_Beddoe
Message 5 of 7
You will need to plug in a phone, to prove whether its a problem with the line itself. You can buy a cheap wired phone for less that £10.
Tanyab
Message 6 of 7
Just tried a wired phone. Works perfectly, can receive calls and call from it.
imjolly
Message 7 of 7
if you have a dial tone then line ok so looks like the flashing purple there is no internet connection  you need to phone customer services and get connected/activated
