jbscotland
Message 1 of 12
BT INFINITY WITH HH5 CONTINUALLY DROPPING CONNECTION AND RESETTING
Hello,
As the title says I have been experiencing concurrent disconnection issues over the past few months. The internet will completely lose connection and the home hub often resets itself - all devices lose connection. When using the xbox to play games with friends I will continously lose connection to xbox parties and it will result in a "networking error" on the xbox. I know this is related to my HH in someway becasue it does not happen to anyone else.
All devices are connected through WIFI and the option for an ethernet cable is not really on the table as the HH is situated too far from these devices.
Any help on the matter would be really appreciated as it is becoming very annoying.  Please let me know what additional information you require on the matter
11 REPLIES 11
imjolly
Message 2 of 12
Re: BT INFINITY WITH HH5 CONTINUALLY DROPPING CONNECTION AND RESETTING
So is the hh5 dropping internet connection or is the problem your devices are dropping wireless connection to the hh5?
have you split the 2.4/5ghz networks and added a 5 to the 5ghz network to gib over it a different SSID?
can you post stats from hh5 - troubleshooting helpdesk
jbscotland
Message 3 of 12
I have the split enabled. Xbox on 5 and everything else on 2.4. Every device loses connection.
Here is the event log
Time and date Message
18:34:30, 02 Mar.(213759.470000) Admin login successful by 192.168.1.64 on HTTP
18:34:30, 02 Mar.OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.64]:54097-​>[188.255.92.111]:14917 on ppp3)
18:34:29, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [93.73.90.223]:4402 CLOSED/SYN_SENT ppp3 NAPT)
18:34:28, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [87.185.111.86]:54986 CLOSED/SYN_SENT ppp3 NAPT)
18:34:26, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [93.73.90.223]:4392 CLOSED/SYN_SENT ppp3 NAPT)
18:34:23, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [23.31.208.234]:6889 ppp3 NAPT)
18:34:21, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [87.185.111.86]:54495 CLOSED/SYN_SENT ppp3 NAPT)
18:34:17, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [180.150.48.101]:45680 CLOSED/SYN_SENT ppp3 NAPT)
18:34:15, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [46.165.13.145]:43489 ppp3 NAPT)
18:34:11, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [178.34.162.7]:19062 CLOSED/SYN_SENT ppp3 NAPT)
18:34:11, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [93.73.90.223]:4362 CLOSED/SYN_SENT ppp3 NAPT)
18:34:09, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [82.25.236.65]:22135 ppp3 NAPT)
18:34:09, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [77.172.61.107]:51015 ppp3 NAPT)
18:34:07, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [87.185.111.86]:54898 CLOSED/SYN_SENT ppp3 NAPT)
18:34:01, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [68.193.172.115]:15985 ppp3 NAPT)
18:34:00, 02 Mar.(213730.070000) New GUI session from IP 192.168.1.64
18:33:58, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [93.73.90.223]:4644 CLOSED/SYN_SENT ppp3 NAPT)
18:33:57, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [188.63.18.14]:41478 ppp3 NAPT)
18:33:52, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [93.73.90.223]:4623 CLOSED/SYN_SENT ppp3 NAPT)
18:33:52, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [87.185.111.86]:54366 CLOSED/SYN_SENT ppp3 NAPT)
18:33:51, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [218.191.222.3]:6881 ppp3 NAPT)
18:33:46, 02 Mar.IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [137.97.162.124]:16762 ppp3 NAPT)
18:33:45, 02 Mar.IN: ACCEPT [54] Connection opened (Port Forwarding: UDP [192.168.1.64]:50904 <-​-​> [81.129.162.124]:50904 -​ -​ -​ [79.255.103.142]:20159 ppp3 NAPT)
jbscotland
Message 4 of 12
Here is the helpdesk.
1. Product name:BT Home Hub
2. Serial number:+068543+NQ53709744
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 18/07/17
4. Board version:BT Hub 5A
5. DSL uptime:2 days, 11:24:49
6. Data rate:20000 / 79050
7. Maximum data rate:26692 / 76934
8. Noise margin:9.3 / 5.4
9. Line attenuation:13.3 / 13.7
10. Signal attenuation:13.2 / 13.7
11. Data sent/received:2.2 GB / 87.5 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-6TSN
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-6TSN5GHZ
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:8c:10:d4:15:29:00
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
imjolly
Message 5 of 12
so this is a wireless problem not that your hh5 is dropping internet connection    have you thought of something like a wireless access point to extend your wifi
you could also select the wireless channels manually rather that leave it on auto
jbscotland
Message 6 of 12
Oh really? Thank you for the quick reply. I dont think a wireless access point would help too much as the HH is not situated too far from any device. No less than 10 metres between any of the devices. What channel would you recommend?
Keith_Beddoe
Message 7 of 12
Turn off smart wireless, and manually select channel 13, that is usually quite good.
You also have a device at IP address 192.168.1.64 which keeps opening and closing port 50904, are you aware of that?
imjolly
Message 8 of 12
Get a wifi analyser for phone or inssider for pc and that will show you channels in use and then try and select a free channel in hub
jbscotland
Message 9 of 12
That would be my laptop. Is there anyway to fix this?
Keith_Beddoe
Message 10 of 12
Go into the home hub settings and disable UPnP, that should stop it. That might also be the cause of your disconnections.
If you do not know what is causing it, then you may have spyware or a trojan program running on your laptop. Its not a known port number.
