Message 11 of 12
Re: BT Infinity Hub v4 - range extender issues BT 500 kit
I cannot suggest anything else at the moment. I have used TP Link powerline adapters in different places in my house, and even down to the garage, without any issues.
I have the older type of fuseboxes, with removable fuses, so if your wiring is new, perhaps you have RCDs fitted, which may be affecting the signal strength.
You may have to end up running an Ethernet cable, which is what I use to connect my home hub downstairs, to the upstairs room where most of the computer related stuff is.
Richarddixon
Message 12 of 12
ok, thanks for trying
