jaded
Newbie
Message 1 of 8
BT Infinity - slow
Hi Guys !
Fibre to cabinet then copper to house.
New filters ,set up ,  etc , all as instructed .
Hub is new BT 5.
Connection is wireless - 5M to hub through one 150mm breeze wall , using secondary phone socket.
6 days since install.
Promised speed 35 - 40 meg.
Actual ( using various testers ) 19 down , 9 up.- constant.
Have tried restarting hub - to no avail.
Have phoned Mr. India - reported "line fault - which was shown as "fault cleared " in ! hour.
Now feeling ripped off / pi**ed off / & generaly I DONT KNOW WHAT ELSE TO DO !!
HELP ,
jaded
7 REPLIES 7
Message 2 of 8
Re: BT Infinity - slow
You need to measure the speed using an Ethernet cable only.
Message 3 of 8
Turn off "smart set up" on the homehub, see link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
When ever you do a speed test it should be done with a wired connection. There are too many variables to give an accurate reading if it is done with a wireless connection.
Can you run this checker and post back a screen shot of the results
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Distinguished Guru
Message 4 of 8
You can maybe check your sync speeds on the Homehub 5.
Here's how - click this link http://192.168.1.254/index.cgi?active_page=9140&active_page_str=page_hdesk&req_mode=1&mimic_button_f...
u may have to login with the admin password found on the Card with the Wireless key first then reclick the link.
If not, I'll try again 🙂
jaded
Newbie
Message 5 of 8
Sorry - cant get a cable from hub to computer .
Distinguished Guru
Message 6 of 8
No need to measure, the Homehub5 tells you.
jaded
Newbie
Message 7 of 8
Have turned off "smart set-up ".
Unfortunately I can not get a cable from Hub to computer !
Will speed test & let you know .
jaded
Newbie
Message 8 of 8
Hi Again Guys !!
slow infinity speed (wireless ) SOLVED by off duty BT Engineer.
fitted TP-LINK direct at computer into ethernet port.
Result - 37.5 down : 9.1 up
However - many thanks to all who offered help.
