Message 11 of 27
Re: BT Infinity with Cisco Umbrella (OpenDNS)
@Dave1111
As mentioned in my personal message, I will be adding the firewall settings for OpenDNS to my website. I need to get some screeshots first.
Dave1111
Message 12 of 27
OpenDNS is working fine at the moment having configured the two DNS addresses and using the Umbrella roaming client.
The thing that isn't working straight out the box is YouView.
Dave1111
Message 13 of 27
EDIT: YouView now working. The DHCP Server is by default turned off on the IPTV LAN interface.
Message 14 of 27
@Devon_Dave gave the settings that worked.
@Dave1111
I have created a draft web page describing the method I used to configure the firewall. I hope I have not missed anything out.
I may need to edit it a bit, but I hope it makes sense Smiley Wink
Take look at it, and see if you understand what is going one. I will leave you to play with it.
This is the link.
Draft document showing firewall settings for Opendns
You can try and see what happens if you change the DNS servers on a computer, to something like Google public DNS.
You may have to flush the computer`s DNS cache to see the effect.
Its odd that TP-Link dropped the configurable firewall options on their later routers.
Dave1111
Message 15 of 27
Thanks. Your link just redirects me back to the BT forum.
Message 16 of 27
You must access it from your BT Broadband connection, as my webserver has domain restictions on it.
All other access will either display a public page, or redirect back to the forum.
Dave1111
Message 17 of 27
Got it now - thanks Keith!
Message 18 of 27
I hope it all makes sense, as i put it together quickly. Let me know how you get on, so I can make any amendments.
I need to do a bit of editing of the image sizes, as they may be a bit on the large size, as they are just screen captures from my spare TP Link, with a bit of editing using Paintshop Pro.
As I mentioned on that web page, you can add extra rules after those three OpenDNS rules, to block websites to individual devices if needed. This is on top of that provided by OpenDNS.
It works better than the rather limited (white list) parental controls implemented by TP-Link.
Dave1111
Message 19 of 27
The TL-WR802N has been in and working for a few weeks now. Wireless coverage is good, perhaps a shade less distance than my previous HH5, but close.
However, I get constant dropouts throughout the day. I work from home and rely on Skype-for-Business for calls, so it's quite disruptive. The dropouts only last several seconds and I don't lose connection but it's a pain as they happen about every 20-30 mins.
I'm on a Windows 8 laptop. I see the wireless bar logo (near my battery logo) go from 4-5 bars to none + a star symbol for a couple of seconds and then it comes back again.
The HH5 also dropped out but that was a DSL issue about once a day when I'd completely lose connection.
I can't seem to find anything useful in the logs either. I'm set to debug level. The only thing I see is a DHCPD message that coincides with it.
Thoughts anyone?
Message 20 of 27
The TL-WR802N is a travel router, so I am confused?
