Maremy46
Message 1 of 2
BT Mini Wi-Fi Home Hotspot 600 Multi KIt
I have just set up a BRT Mini Wi-FI Home Hotspot 600 Multi Kit with one hotspot  in the living room and the other in the kitchen.
Each hotspot has all three of its lights on green
However I was uanable to log on to the extended network with my wife's ipad and iphone SE - on each occasion I received a message saying there was no internet connection.
Any thoughts gratefully received
1 REPLY 1
lnajr02
Message 2 of 2
Re: BT Mini Wi-Fi Home Hotspot 600 Multi KIt
Check out the BT Help pages, search "Mini Wi-Fi Home Hotspot 600 help" but some Things to check :
LED status on the Hotspot. ( see quick start Guide )
If your home is older just check that the units are connecting, move to the same double power socket same room check if you can connect. if yes it could be a problem with house wiring or you are not on the same consumer unit. If you still have a problem call phone: 0808 100 6116 ( Helpdesk) hope this helps.
