Message 1 of 7
BT Router & Wifi
I currently use a bt router as a wifi repeater in addition to main one. If I moved to another provider, thus another main router (sky) would my BT one still work as a repeater?
6 REPLIES 6
BT TV Expert
Message 2 of 7
Re: BT Router & Wifi
@paulpa66
Hello, to answer your question, yes it should work as long as your using the hub from your service provider as the DSL modem. Our BT hub as other should be able to be a repeater like you are now... however, this type of setup is unlikely to be supported by your new service provider so I would keep this in mind if you have any problems in the future.
That said, sorry to hear you're considering changing provider, is there any particular reseason why you are thinking of leaving us? Are you having problems with your BT service, or are you leaving due to a competitive deal?
Either way, if you would like to consider staying with us, we can look at both. Feel free to drop me a private message and I will be happy to help.
Kind regards, Jack
Message 3 of 7
Thank you.
Leaving on price, i find it insulting when companies offer better deals to new cutomers and ignore those that have been loyal for 20+ years.  You may gain a new customer but you lose one too.
BT TV Expert
Message 4 of 7
Thanks for getting back to me. Sorry to hear you feel that way, I understand where you're coming from.
As mentioned previously, feel free to private message me with your BT landline number and I'll happily take a look at what we can offer.
Thanks, Jack
Recognised Expert
Message 5 of 7
@paulpa66wrote:
Thank you.
It's a standard business practice.
Just play the game & ask for a better deal, which BT will often offer. If they don't and/or you can get a better deal then way up the pros & cons of moving.
Recognised Expert
Message 6 of 7
@TimCurtiswrote:
@paulpa66wrote:
Thank you.
It was late when I posted and obviously it should be WEIGH not WAY. Smiley Embarassed
Message 7 of 7
Thanks Jack for looking into this and getting things sorted to our mutual benefit.
