danlocke123
Newbie
Message 1 of 9
BT SimplerNetworks Powerline Adapter with TL-PA251
Hi There,
We recently had BT infinty installed, at which point the engineer moved our router, removing the need for powerline adapters for the BT Vision box. I immediately hooked them up to my computer and got ~37mb/s, plug-and-play. However, we had another PC at the other end of our house that was no longer in range, so I used the SimplerNetworks adapters with that machine, which once again worked OOB. I bought a TP-LINK TL-PA251 single passthrough adapter on Amazon to use with the first machine, as I wanted the high speed from before. I am using the exact same setup and cannot get a data connection. The power and ethernet lights are lit up but not the data light. I can see the mac address and an IP address on my computer but have no data- I tried to ping google.co.uk but get a 'cannot resolve host' message. I tried swapping the TP-LINK adapter with the SimplerNetworks one hooked up to the router but had no luck, so I put them back.
Can someone help me resolve this?
Thanks,
Dan
8 REPLIES 8
Message 2 of 9
Re: BT SimplerNetworks Powerline Adapter with TL-PA251
did you pair the new powerline adapter with existing adapters?
Message 3 of 9
Interworking between two different makes of adapters, can cause a lot of problems, as there are two different standards.
They cannot co-exist on the same mains wiring.
You may have to stick to one manufacturer, either TP-Link, or Simpler networks.
danlocke123
Newbie
Message 4 of 9
Yes, I held the SimplerNetworks one (connected to the router) for 3 seconds, then did the same with the TP-Link adpater to no avail
Message 5 of 9
While Powerline adaptor brands are meant to be able to work with other brands they rarely do. You should stick to the same make.
danlocke123
Newbie
Message 6 of 9
Hmm ok, I have heard people have had success with the two, specifically with the 'newer' SimplerNetworks ones- we have had them less than six months if that helps.
danlocke123
Newbie
Message 7 of 9
Where can I purchase another SimplerNetworks one?
Message 8 of 9
should you not be pairing the powerline adapters together - no need to hold them beside the hub
Message 9 of 9
A quick search and you should be able to get them on that well know internet auction site.
