Message 1 of 7
BT Smart Hub 2 - Alternative with 4G Sim failover
Hello,
I am looking for an alternative router to the Smart Hub 2 that will support a 4G sim as a failover option when the Fibre goes down.
Any help appreciated.
Thank you
6 REPLIES 6
Message 2 of 7
Re: BT Smart Hub 2 - Alternative with 4G Sim failover
Message 3 of 7
What service do you have VDSL, G.Fast or FTTP?
Message 4 of 7
I am on FTTP
Message 5 of 7
As you don't need a modem/router, just a router, you could also consider the Netgear R7100LG https://www.netgear.co.uk/home/products/mobile-broadband/lte-gateways/R7100LG.aspx
Message 6 of 7
Great, thank you. Do any of these routers need any config? or just plug and play?
Message 7 of 7
They will just need the generic PPPoE username and password of bthomehub@btbroadband.com and BT respectively to connect to broadband but I have no idea about configuring the failover to 4G
