mrjabush
Message 1 of 4
BT Smart Hub 2 - Limited channels
The user interface for BT Smart Hub 2 only offers limited channels. Those channels are in use by my neighbours, so I want to select other channel numbers for both 2.4GHz and 5GHz.
Why can't I select other channels?
Is there a hack / workaround ? Is there another way to configure?
3 REPLIES 3
licquorice
Message 2 of 4
Re: BT Smart Hub 2 - Limited channels
Unfortunately you can't
Because BT think they know best and restrict the channels to non-overlapping channels despite many complaints.
The only workaround is to buy a third party router.
imjolly
Message 3 of 4
No work around. You can only use the channels shown just  use a wifi analyser and then select a channel where your selection will be far stronger than your surrounding neighbours. Alternatively you can purchase a third party router/modem with more choices
Tags (1)
mrjabush
Message 4 of 4
Sad but thanks
