Message 1 of 5
BT Smart Hub 2 & Google Wifi
I Have just placed an order for super fast fibre which includes a smart hub 2, I already own a google Wi-fi and would like to use this mesh system but my question is does the hub have a modem only mode? And if not what is the best modem to buy that will work with both BT & Google Wi-fi?
4 REPLIES 4
Message 2 of 5
Re: BT Smart Hub 2 & Google Wifi
No, it doesn't I'm afraid. Your choice of standalone modem is pretty limited. There is the Openreach HG612 from ebay, Draytek Vigor 130, or Netgear DM200.
Message 3 of 5
Thanks for the reply, so if I buy one of those I can plug that straight into the wall & the google mesh into that?
Message 4 of 5
Yep. You will need to enter username of homehub@btbroadband.com and password BT on the Google mesh.
Message 5 of 5
That’s great thanks for the help 👍🏼
