MarkL1
Message 1 of 6
BT Smart Hub 2 and Panasonic Viera
New router (Smart Hub 2). Panasonic Viera Cast will not connect with the router. Panasonic advice is that router is blocking the TV, and to enter TV's MAC address in the router. So - question is: has anyone else had this issue, and how to enter the address in the router. Thanks!
5 REPLIES 5
Message 2 of 6
Re: BT Smart Hub 2 and Panasonic Viera
Have you turned off smart setup on the hub?
MarkL1
Message 3 of 6
Yes, it's off.
Message 4 of 6
@MarkL1 wrote:
Yes, it's off.
Is this any help Panasonic Viera problem
Its an old thread.
MarkL1
Message 5 of 6
Thanks Keith I'll take a look.
Message 6 of 6
It may help, as I think that sometimes  the BT Home Hubs fail to respond correctly to a DHCP request from certain devices.
If you have devices in your home that never move, then its sensible, wherever possible, to manually allocate a static IP address, outside of the DHCP range.
