Message 1 of 15
BT Smart Hub 2 expansion
My BT Smart Hub 2 has 4 ethernet cable inputs but I'd now like to add a further 3 cable inputs.
I assume I need some sort of splitter with 4 inputs and 1 output to one of the router inputs?
Is there a BT branded splitter or perhaps a recommended one from another manufacturer?
Many thanks in advance.
14 REPLIES 14
Message 2 of 15
Re: BT Smart Hub 2 expansion
You just need an unmanaged network switch, they're easily affordable from Amazon
i.e.
Message 3 of 15
Many thanks for your very quick reply.
Message 4 of 15
Yes, but please delete the link, it is against forum rules.
TP-Link TL-SG105S, 5 Port Gigabit Ethernet Network Switch is cheaper and probably better.
Just connect one of your hub ports to any on the switch to provide 4 extra ports.
Message 5 of 15
Sorry, didn't realise, link deleted.
Thanks to both for your help.
Message 6 of 15
That would do but if you're going to buy one then why not future proof it by going for an 8 port one such as the one in my post.
The rules of the community forbid commercial links being posted and I expect one of the moderators will remove the link you posted in short time but there's nothing to stop you using the graphic I posted as the basis of a visual search
Message 7 of 15
Yes, I guess an 8 port switch is sensible. TP Link do an 8 port.😃😃
@Les-Gibson  I just prefer TP Link to Netgear products, probably irrational
Message 8 of 15
8 port it is then!
I see there's a slightly more expensive version with "Easy Smart" technology.
What is this, please, and is it worth the extra?
Message 9 of 15
Each to his own - I prefer the cheapest and have a selection of redundant 4 port ones, hence my suggestion to go for the 8 port version 😊
Message 10 of 15
Yes, agree go for 8 port, but what is this Easy Smart for an extra £4?
(you'll gather I'm not very technical...)
