Message 1 of 2
BT Smart Hub 5Ghz wifi not working
My Airport extreme finally gave up the ghost and now I have to use the Smarthub.
However the 5ghz wifi doesn't work. My iphone 7 or laptops will connect to the 5ghz.
is this a known fault or is the hub faulty?
Stats:
Product name:
BT Hub 6A
Serial number:
Firmware version:
SG4B10002244
Firmware updated:
18-Apr-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
1 Days, 2 Hours 8 Minutes 2 Seconds
Data rate:
20.00 kbps / 80.00 kbps
Maximum data rate:
32146 / 93460
Noise margin:
15.4 / 9.9
Line attenuation:
11.5
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
623 MB Uploaded / 978 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
Ouranos
2.4 GHz wireless channel:
Channel 1
5 GHz wireless network name:
Ouranos-5
5 GHz wireless channel:
Channel 36
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:9B:0C:29
Software variant:
Boot loader:
7.33.1
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT Smart Hub 5Ghz wifi not working
