jwDave1
Message 1 of 9
BT Smart Hub 6 and NAT
Due to living in a cottage with 2 foot thick stone walls I have had to install a Linksys Velop mesh system. Now I have a 'Double NAT' issue.
I cannot disable NAT on my BT Smart Hub 6 so I have tried every which way to connect an ASUS AC68U but it will not see the internet for love nor money despite several posts I have read about this.
Is there a sure fired way of replacing the BT Smart Hub 6 with the ASUS or is there another router I could buy that will do the job?
I know there has been much on this topic but nothing quite seemed to fix it for me.
8 REPLIES 8
Message 2 of 9
Re: BT Smart Hub 6 and NAT
That asus is a router and what you need is a separate modem hence why no internet connection. You should have bought the modem/router version of asus
you could get a hg612 modem from auction
NoSirItWasntMe
Message 3 of 9
There are actually two versions of the Asus kit.
DSL-AC68U has a built in modem
RT-AC68U doesn't.
jwDave1
Message 4 of 9
Hmm ok thanks, expensive mistake! Thanks again.
NoSirItWasntMe
Message 5 of 9
You should be able to turn the Velop's DHCP server off, have you tried that ?
jwDave1
Message 6 of 9
I cant see any way to turn NAT off in the Velop, I can change the IP range but that is all.
NoSirItWasntMe
Message 7 of 9
@jwDave1
You have to put it in bridge mode.
https://www.linksys.com/ca/support-article?articleNum=243548
It will lose a few monitoring features eg speed testing though.
jwDave1
Message 8 of 9
Yes I did know about bridge mode but I am trying to avoid it as you loose quite a few features, may end up the only answer though!
NoSirItWasntMe
Message 9 of 9
Older versions of the firmware allowed you to access a web config page, bypassing the app, which does allow you to turn off DHCP on the Velop.
See here for an example:
https://support.getcujo.com/support/solutions/articles/9000131538-dhcp-mode-linksys-velop
