ojobson
Message 1 of 3
BT Smart Hub DNS not working - troubleshooting steps?
In the last couple of weeks all devices that were using the Smart Hub for DNS have stopped being able to access the internet. e.g a ping command in terminal will result in "cannot resolve facebook.com: Unknown host". If I change only the DNS to 8.8.8.8 (I've done this on all wired and wireless devices) then connectivity is restored.
I've tried turning the router off and on - what other trouble shooting steps should I be taking?
Router software is SG4B1000B540. I'm on FTTH.
Thanks,
___________________________________
My Blog: oliverjobson.co.uk
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: BT Smart Hub DNS not working - troubleshooting steps?
try factory reset of the hh6 by holding the recessed button on back for 20/30 sec until lights flash  remember to turn off smart setup after reset
ojobson
Message 3 of 3
Thanks - seems drastic... is uploading the saved config file to the router usually a reliable process? I have a well defined network environment and I don’t want to spend ages reconfiguring static IPs and port forwards.
