lhrwilson
Message 1 of 2
BT Smart Hub as AP
Is it possible to use a secondary BT Smart Hub as an additional Access Point alongside the primary BT Smart Hub?
I know it was possible with the BT Hub 5 but want to know if its possible with the Smart Hub?
Tags (2)
1 REPLY 1
Message 2 of 2
Re: BT Smart Hub as AP
See this post https://community.bt.com/t5/Connected-Devices-Other/BTHub6-Smart-Hub-As-WiFi-Extender-or-AP-Access-P...
Perhaps you would be kind enough to confirm whether this works for you. Thanks.
