moorhen2
Message 1 of 16
BT Smart hub
Just ordered the new BT Smart Hub, being deliverd on Thursday, question is will it fit through the letterbox like the HH5, cant seem to find any info about this. ??
15 REPLIES 15
Bodge
Newbie
Message 2 of 16
Re: BT Smart hub
Yes will go straight through the door
Message 3 of 16
Re: BT Smart hub
didn't fit through my standard letterbox - too deep - length and breadth were ok
moorhen2
Message 4 of 16
Re: BT Smart hub
Thanks guys. Smiley Happy
Distinguished Expert
Message 5 of 16
Re: BT Smart hub
It would fit through my letter box, but postman said that he would not have tried.
If this is the case, and you have neighbours, he will try to deliver to them.
MarkyR74
Message 6 of 16
Re: BT Smart hub
How do you order the new Smart Hub 6? Do I have to call them or can I buy it online? I'm an existing Infinity customer.
moorhen2
Message 7 of 16
Re: BT Smart hub
Thanks for reply, i think thats what happened with my HH5, postman never even tried to put it through letterbox, even though it would have gone through very easily.
IanLoughlin
Message 8 of 16
Re: BT Smart hub
I'd like to order one but I think the £7.95 delivery charge is too much. Can I reduce this charge or pick one up from somewhere? The attraction of the deal (£50) is reduced by adding a hefty delivery charge.
Message 9 of 16
Re: BT Smart hub
@IanLoughlin
it's a standard charge
Message 10 of 16
Re: BT Smart hub
Try ebay. There might be one on there with a cheaper delivery charge failing that you will need to pay what BT want.
