advent1307
Message 1 of 5
BT SmartHub
Please can someone advise am I able to use my own router instead of the smarthub - I don't want to spend on a decent router to get my setup right and find it does not work
4 REPLIES 4
licquorice
Message 2 of 5
Re: BT SmartHub
Yes, of course you can. Just make sure it is a VDSL modem/router.
Keith_Beddoe
Message 3 of 5
Re: BT SmartHub
Welcome to this user forum. @advent1307
Of course you can Smiley Wink
Here is one suggestion
TP-Link AC1200 Wireless Dual Band VDSL/ADSL about £67
https://www.tp-link.com/uk/products/details/cat-15_Archer-VR400.html#specifications
Or
Asus DSL-AC68U
https://www.asus.com/uk/Networking/DSLAC68U/
There are also cheaper single band wireless VDSL Moden/routers starting at about £40.
Keith_Beddoe
Message 4 of 5
Re: BT SmartHub
As @licquorice  has said, it has to be capable of direct connection to your phone line, so it has to have an integrated modem.
A wireless router is not suitable, unless you buy a separate modem at additional cost and complication.
If you want to mention what you are thinking about, just post the description in plain text, without any links to any commerce sites.
The links I have posted, go the the manufacturers website which show the specifications but not the price.
DavidM
Moderator
Moderator
Message 5 of 5
Re: BT SmartHub
Hi @advent1307  and welcome.
Thanks for you post. @Keith_Beddoe  and @licquorice  have posted some great replies here. If you do decide to go with another routr post back and let us know how you get on.
Cheers
David
