Kais_1
Message 1 of 6
BT Smarthub upgrade
Hi
I wanted to know what router is compatible with my setup...
Superfast Fibre 2 Unlimited
smarthub
which is the very latest router with i hope built in modem capabilities that i can get.
i have been reading about tomato routers....
so maybe one that has that built in.
i want a router where i can setup advanced security features and firewall...
any help would be appreciated.
Mo
5 REPLIES 5
licquorice
Message 2 of 6
Re: BT Smarthub upgrade
Tomato isn't a make of router, its third party firmware that can be flashed to routers.
Any VDSL modem/router is compatible with SF2, only you can decide by looking at the features which one you want. Possibly best to avoid Netgear as they don't support BTs implementation of IPv6 unless they have changed their minds recently.
Kais_1
Message 3 of 6
which is the best vdsl router then in that case?
all singing and dancing model
Kais_1
Message 4 of 6
how about this model....
Netgear Nighthawk X4S 5-port Wireless VDSL Router
will that work...or is there a better model?
Kais_1
Message 5 of 6
ive just seen this on amazon
ASUS RT-AX88U Wireless-AX6000 AiMesh Dual Band Gigabit Router, OFDMA + MU-MIMO tech, 1024 QAM, Range Boost, Trend Micro AiProtection Pro, WTFast GPN, Dual WAN Support, 3G/4G Support
will it work ?
imjolly
Message 6 of 6
that's just a router  your need the modem/router version
