Mickeydoo1234
Message 1 of 6
BT Smartub 2 not working with alexa echo
I have upgraded to smart hub 2., However, none of my devices controlled by alexa will now work. Had absolutely no problems before i updated. can anybody help me ?
5 REPLIES 5
albertj
Recognised Expert
Message 2 of 6
Re: BT Smartub 2 not working with alexa echo
Have you put the smart home devices back on your new Wi-Fi Network successfully?
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Keith_Beddoe
Message 3 of 6
@Mickeydoo1234
First try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
If that does not help, then turn off the Smart hub  5GHz wireless, then try connecting your smart devices again, remembering that the new hub will have a different SSID and wireless key.
Once everything is working, and all devices including any phones, are connected to 2.4GHz, then you can turn the 5GHz wireless back on, but only if you have any devices that can connect to 5GHz.
Mickeydoo1234
Message 4 of 6
no, it will not discover any smartlife devices
albertj
Recognised Expert
Message 5 of 6
Can you control them via the app on your smartphone?
Mickeydoo1234
Message 6 of 6
thank you, everything back up and working now
