Message 11 of 12
Re: BT Sport Drops After 30 Mins - Netgear Nighthawk R9000 X10
You could try Voxels firmware to see if that helps as NG have some pretty dated packages.
you need to search smallnetbuilders and read up. I don’t expect any updates as it’s EOL which means NG will no longer support the router, sometimes they release a full version as it’s a hot fix which is the latest.
Message 12 of 12
Thanks Stu I'll try that, I've got BT fixing the broadband their tech guy said theres a fault on the line and that could be the reason he also say when you check the support bt proxy that should be it done so if the fix doesn't work I'll move onto your suggestion thanks again for replying.
