Moderator
Moderator
Message 41 of 41
Re: BT Web Address Help opt out isn't working
Hi @jamiekay thanks for the update and glad to hear it's fixed @DanielS is not in the office today but he will be back tomorrow.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
