FourJs2019
Message 1 of 6
BT Whole Home
Trying to add a 7th disc
Shows on web
Not on app.
How many discs can you have ?
5 REPLIES 5
NeilO
Moderator
Moderator
Message 2 of 6
Re: BT Whole Home
Hi @FourJs2019 welcome to the community and thanks for posting, I've checked the FAQ's and 6 discs are currently supported.
FourJs2019
Message 3 of 6
Re: BT Whole Home
Looking to add a 7th
lnajr02
Recognised Expert
Message 4 of 6
Re: BT Whole Home
You must have a home with Wi-fi problems or its massive, are you looking to add a seventh disc as you have a Whole Home problem or do you just like the look of the discs?
FAQ https://btsupport.custhelp.com/app/answers/detail/a_id/59137/c/8071 confirm that the App and WEB GUI only supports six.
FourJs2019
Message 5 of 6
Re: BT Whole Home
Wi-Fi blackspots and 1 in the garden
NeilO
Moderator
Moderator
Message 6 of 6
Re: BT Whole Home
Hi @FourJs2019 I'm sorry you'll not be able to add another disc as the maximum number you can connect on the BT Whole home wifi system is 6.
