Hello
I currently have my home set-up with the BT WholeHome kit where I have two discs. Both discs working together enable me to achieve my minimum guaranteed speed throughout the entire house. Due to the nature of the walls and structure, two discs were required.
I’ve been offered Complete Wifi by BT but I’m thinking is it worth it seeing as though I already have WholeHome which does what I need it to do? What’s the difference between the two services? Shall I keep my package as is (it would be an extra £10pm if I decided to go Complete WiFi!)
Would be nice to hear if any other customers are on the WholeHome service and if they’ve made the move to Complete WiFi - and if there was any difference?
Also -
My minimum guaranteed speed if I moved from WholeHome to Complete WiFi would REDUCE by a few mbps. Another reason I’m reluctant to make the change.
Thanks all,
Dan
