Johnnyboy1964
Message 1 of 4
BT Wholehome Discs Ethernet port
I Have a summer house and have my 5th Wholehome disc in there which works quite well although always on yellow due to the distance from the nearest disc.
I have recently installed a Wired Ethernet cable out to the summerhouse and plugged it into the back of the whole -home disc thinking it may improve the wi-fi but the disc is still indicating a yellow light and i don't thing the Wired ethernet connection has changed it at all.
I believe the ethernet port on the back of the disc is for plugging directly into a smart TV or Network music player.
I cannot find any conclusive information in relation to this.
DO i have to change the settings on the disc as i cannot seem to find out where to do this.
Any help would be awesome.
Regards,
J
3 REPLIES 3
lnajr02
Recognised Expert
Message 2 of 4
Re: BT Wholehome Discs Ethernet port
Depending on the Whole home version the Ethernet method changes have you Whole Home Original (GEN1) or Mini or Premium?
Johnnyboy1964
Message 3 of 4
Hi ,
How do i know,
I cannot remember seeing any info on my bill.
i have had them about a year now!!
John
lnajr02
Recognised Expert
Message 4 of 4
Assuming the age and if they are White , they should be GEN 1 (Dual-band AC2600) see https://shop.bt.com/products/bt-whole-home-wi-fi-088269-CDXH.html?refs=60460000
Check the App under discs detail (Connection) you should see Ethernet, I am assuming both are connected direct to the HUB!
