Message 1 of 4
BT WiFi Disc/Ring Doorbell Pro ?
Hi,
I have just upgraded my Ring Doorbell to the Ring Doorbell Pro and I could do with a slightly better WiFi connection  between the Ring and the BT Home Hub 2.
Would I be wasting my hard earned cash by buying a black BT wifi disc to achieve a better WiFi signal for the Ring Doorbell Pro ?
3 REPLIES 3
Message 2 of 4
Re: BT WiFi Disc/Ring Doorbell Pro ?
Are you experiencing any problems? I do something similar with an Orbi satellite to get a better RSI number otherwise the connection wasn’t that great for viewing.
Message 3 of 4
Yes, just a wee bit of a lag and the RSSI on my old Ring Doorbell was 70 and that's pretty rubbish.  It's a bit lower with the Ring Pro, but if the BT disc makes it better, I'm willing to give it a try.
I have tried a few BT wifi extenders, but they don't make any difference.
Message 4 of 4
@152bobby It definitely made a huge difference for me, I cannot think of any reason it wouldn’t for you too. Good luck!
