Mustafa_Islam
Message 1 of 2
BT WiFi hotspot bypass around access control
I have my brother’s android phone on access control with the bt smart hub 6. But some how the hub allows him to connect to the BT WIFI with Fon broadcast so the access control has no use. I even have him on a timed access on my ASUs rt N66U Access Point router but his room is close to the bt hub so has no effect. Is this suppose to happen?
____________________________
If I helped out then leave my reply a Kudos by clicking the thumbs up button
1 REPLY 1
Message 2 of 2
Re: BT WiFi hotspot bypass around access control
Access control would not work on BT Wifi as its a totally separate connection.. Delete the BT WiFi app from the phone, unless he is the account holder. The other option is to ask the account holder to change the BT ID password so that the app does not work.
