Frizzel
Message 1 of 2
BT Wifi with FON connection for Smart TV (Philips 65PUS6523)
I'm a BT customer and I've just moved into a new flat with a strong BT Wifi with FON connection. I'm using this connection for my TV until I get broadband installed. The only annoying thing is that I have to reconnect through the browser each time and it doesn't have the 'remember me' functionality to have a preset username and password.
Does anyone know if there is a way to get around this?
1 REPLY 1
gg30340
Message 2 of 2
Re: BT Wifi with FON connection for Smart TV (Philips 65PUS6523)
Depending on which browser you are using the browser may have the function to remember user names and passwords. The function is usually found in the browser's settings and has a tick box to turn it on or off.
It used to be the case that you could not stay logged on to BTWifi. It used to automatically throw you off after two hours and you had to re log on in order to use it.
