Message 1 of 2
BT Youview on PFsense
I have a PFsense router set up but I cant' seem to get the internet channels working on my youview box (like AMC and SyFy).
What settings will I need to use to get it working properly. I get the error saying IPC 6023. Thanks 🙂
1 REPLY 1
zarf2007
Message 2 of 2
Re: BT Youview on PFsense
unless it can do igmp proxying i think you are out of luck.....check out the non bt router threads on this forum.
