barneys
Message 11 of 17
Re: BT ZXHN W151N wireless N adapter Does not work out of the box
Roger. Sorry you've got me there. How do I check for Plug & PLay being switched off.  I am not sure about Install new hardward Wizard in Win 7 either.
Message 12 of 17
go to control panel in start and then hardware then add new device.  can you see adapter in device manager when connected?  maybe with yellow '?' or '!'
ach2
Message 13 of 17
Scan for new hardware in win 7 is similar to XP etc...
Start / Control Panel / System / Device Manager
When device manager is open there should be an icon which says 'scan for hardware changes' in the second line.
barneys
Message 14 of 17
OK Roger. Done that. Yes the adapter is listed in the device manager as an unspecified item. and yes it as a yellow '!'
Guru
Message 15 of 17
It's not picking any drivers up then  .....
Is there a proper installation CD you say .... if you installed correctly there will be a wizard in the desktop menus somewhere to setup the adapter to look for networks .....
USB wireless network adapters can work in ONE of 2 ways ... either by Windows network setting it up ....
or by the manufacturer's drivers and software (wizard) setting it up .... to look for networks.
If you installed any software with your old usb adapter, you may have to uninstall it, as when the computer is started the win.ini will be loading drivers for that ....
Then start afresh with the new software (CD) and instructions.
barneys
Message 16 of 17
Ok Thanks Roger. I have to be somewhere this Evening so I'll have to pick this up tomorrow & check this out. Thanks for all your your help so far.
barneys
Message 17 of 17
OK I have now returned to this problem. I have removed all traces of the old adapter driver by uninstalling the adapter from Control Panel "remove software" then re-booted PC. Also removed all the old redundant folders related to old adapter. I ten plugged in the new adapter and it picked up the drivers and it is now working OK. As suggested it must have been the old software\drivers messing things up. Thanks everyone for your help.
