Message 1 of 3
BT acdongle
Hi all
Does anyone know if I have to set up acdongle on the laptop before I use it in a DVD player.
2 REPLIES 2
Message 2 of 3
Re: BT acdongle
If you are talking about using a BT Dongle in order to connect a DVD player to the Internet you will find that it won't work. You will need to use the DVD player manufacturer's wireless dongle. This is because the DVD won't have the drivers installed to make the BT Dongle work and there will be no way to install those drivers.
Message 3 of 3
Re: BT acdongle
Ok thanks for your help
