Kevyn
Message 1 of 3
BT complete Wi-Fi and Halo. Wi-Fi Disc issue
Hello, Pulling my hair out with this one!
I have a BT Smart Hub 2 and 3 X Wi-Fi discs (black discs).  Up until this point the three discs have been rock solid,  giving me WiFi  throughout my property, faultlessly.
Now 2 of the 3 discs will not connect to the Smart Hub 2 wirelessly.
Background
On Wednesday I noticed that one of the discs was flashing blue indicating it was trying to make a connection to the smart hub.  After rebooting,  the disc displayed a consistent red flashing light.
My assumption was that the disc had lost its configuration.
I removed the red flashing disc from its home location ,moving  it to around 3 meters (line of sight) from the Smart Hub.  I proceeded to try and re-configure the wifi disc to connect to the Smart Hub 2.
I have tried both  Ethernet and the WPS configuration methods.  Trying both the Smart Hub 2 config. via “add new wifi disc” (advanced wireless/configuration/my discs) and Android “My BT” App. Add new disc wizard.
Ethernet configuration registers the disc on the network, producing a solid blue light (have left connected to Ethernet for  12 hours) .  However, once removing the Ethernet cable and rebooting the disc the disc changes to either red flashing or blue flashing.  This is within 3 meters of the hub, in clear line of sight.
Using WPS will a) not pick up the disc or b) will attempt to add the disc (asking me to provide  a friendly name for the disc) but when wizard finishes the discs drops back to flashing blue then flashing red.
I have tried using the factory reset pin (pressing for 10 seconds whilst powered) and waiting for reboot. To no avail
I have also unplugged my working garage black disc (which was again, working flawlessly for over 6 months) with the intention of replacing  what I Have deemed as a faulty disc.  However on startup the once working disc will no longer connect.  Tried the same failed steps, as above.
I now have two discs that will not connect to my Smart Hub 2.  The third disc has not been unplugged and is still working and connecting clients.  I am obviously reluctant to power this disc off as its working fine!
  • I have rebooted the Smart Hub 2 several times, to no avail.
  • I have had no mains power cuts, surges or spikes (I have a UPS that will alert me if the mains fluctuates).
  • The Android “My BT” app indicates that each one of my disc locations has either “good” or “excellent” wifi signal from the Smart Hub 2 and has been such for 6 months+.
After spending hours on this, I have spoken to BT and they are not sure what is wrong but are sending replacement discs, which I suspect will not make any difference (2 discs with the same fault) after disconnecting.
I am suspecting a Firmware issue here.  I did notice that BT appear to rolling out firmware for the discs. One of the broken discs upgraded firmware revision  whilst connected to Ethernet.
Smart Hub 2 Firmware
Firmware version:v0.17.01.12301-BT
Firmware updated:Sat Mar 14 14:05:41 2020
BT Complete Disc firmware (x3)
Firmware version:
0.16.00.07230
I am very reluctant to reset my Smart Hub 2 to factory defaults, owing to having reconfigure  detailed config.  (password, SSID, Wireless, Firewall rules, VPN, DHCP reservations etc etc).
I am also assuming that a factory reset and a restore of config (from backup) would probably NOT be recommended.
I could really do with somebody technical who knows some detail about this stuff and how it meshes together.
Anybody else having these problems recently?
Many thanks for your help
2 REPLIES 2
LordDarkenon
Message 2 of 3
Re: BT complete Wi-Fi and Halo. Wi-Fi Disc issue
Did you manage to get anywhere with this?
I'm having the same issues with SH2 and 2 black complete wifi discs.  They keep on disconnecting every couple of days - I usually notice in morning when they are flashing red.  Usually turning the SH2 off and on will make them re-connect - but this isn't a solution.
I started with 1 disc, which worked without problem since installation for about 6 weeks, and then over the last couple of weeks I've had disconnects every couple of days.  I contacted BT and had another disc sent out, and that has the same problem.
It's got to be a firmware / software issue.  It's like rebooting the SH2 clears a temporary cache, and when that gets full after a couple of days the discs disconnect again.
I'm at the point of disconnecting them completely since I don't want to be rebooting my SH2 every couple of days.
Another BT issue they seem to be ignoring - or the forum moderators just reel out the old chestnut 'have you tried resetting your hub and discs' - as if that's a solution you can do every couple of days.
Kevyn
Message 3 of 3
Sorry for delay in responding - no didn't get anywhere with my post here, however in the last few months the disks and the router seem to have stabilised , I am assuming this is to do with maybe a firmware update on the disks?
The disks are all now running
Firmware version:
0.23.00.0807
If any of the disks lose connection I find I have to reboot the SH2 (router), and they magically reconnect.
