Newbie
Message 1 of 2
BT home hub6 and Xbox one
Help - sorry in advance
I have an Xbox one and play WW2, my issue is that the game shows an open NAT and the console shows as moderate and I am having issues connecting etc for gameplay.
I have Upnp enabled and also have the relevant ports forwarded, both of these run at the same time. Is this causing a conflict, if so, which should i use, Upnp or Port forwarding?
Also, does anybody have an idiots guide - for me - to correctly Port forward on the Home hub 6 with an Xbox one, including things others may take for granted, ie static IP setting etc, basically a step by step tutorial would be excellent and very much appreciatted
Many thanks
Rich
1 REPLY 1
Expert
Message 2 of 2
Re: BT home hub6 and Xbox one
MW and COD games have always said that, personally never had any issues.
If you can connect to a lobby and if party chat works then all is well.
