Message 1 of 2
BT home mesh vs...
Was just about to buy some discs and noticed the product is 8 years old.
Is there anything newer/better I should look at.  Its for an old country cottage with thick walls. (But most of it is covered right now by our router - penetrating ceilings and plaster walls)
1 REPLY 1
Message 2 of 2
Re: BT home mesh vs...
@Gherkin
Are you a BT Broadband customer?
If you are just looking for coverage in one extra area, then a wireless hotspot is a cheaper option.
Like https://www.tp-link.com/uk/home-networking/powerline/tl-wpa4220-kit/
