PAPADELTA
Message 1 of 18
BT infinity with a Cisco router
Hi All,
I would like to install BT infinity with a Cisco router 867VAE-K9.
My first question is do I have to use white BT openreach modem?
We a can find config for this router?
Thanks,
Papadelta
17 REPLIES 17
imjolly
Message 2 of 18
Re: BT infinity with a Cisco router
as it is just a router you need a vdsl modem
PAPADELTA
Message 3 of 18
Thank you for yours replay.
Papadelta
PAPADELTA
Message 4 of 18
BT infinity with a Cisco router.
Hi All,
Where a can find config for this router, or who can help me,
Papadelta
licquorice
Message 5 of 18
Re: BT infinity with a Cisco router.
The settings you require are PPPoE, username bthomehub@btbroadband.com, password bt, VLAN 101. Any other settings and where and how to enter those settings are best asked on a Cisco forum.
Have a look at this thread https://community.bt.com/t5/BT-Infinity-Fibre-broadband/Infinity-on-Cisco-Router/m-p/149185/highligh...
PAPADELTA
Message 6 of 18
Hi licquorice,
I Tryed everifing, but not working for me. Could you look please.
ROUTER#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ROUTER(config)#no service pad
ROUTER(config)#service tcp-keepalives-in
ROUTER(config)#service tcp-keepalives-out
ROUTER(config)#service timestamps debug datetime msec
ROUTER(config)#service timestamps log datetime msec
ROUTER(config)#no service password-encryption
ROUTER(config)#!
ROUTER(config)#hostname ROUTER
ROUTER(config)#!
ROUTER(config)#boot-start-marker
ROUTER(config)#boot-end-marker
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#no enable secret
ROUTER(config)#no enable password
ROUTER(config)#!
ROUTER(config)#no aaa new-model
ROUTER(config)#wan mode ethernet
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#ip domain name qwest.net
ROUTER(config)#ip name-server 205.171.3.65
ROUTER(config)#ip cef
ROUTER(config)#no ipv6 cef
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#!
ROUTER(config)#controller VDSL 0
ROUTER(config-controller)#shutdown
ROUTER(config-controller)#!
ROUTER(config-controller)#interface Loopback0
ROUTER(config-if)#no ip address
ROUTER(config-if)#!
ROUTER(config-if)#interface ATM0
ROUTER(config-if)#shutdown
ROUTER(config-if)#no atm ilmi-keepalive
ROUTER(config-if)#!
ROUTER(config-if)#interface Ethernet0
ROUTER(config-if)#no ip redirects
ROUTER(config-if)#no ip unreachables
ROUTER(config-if)#no ip proxy-arp
ROUTER(config-if)#!
ROUTER(config-if)#interface FastEthernet0
ROUTER(config-if)#!
ROUTER(config-if)#interface FastEthernet1
ROUTER(config-if)#!
ROUTER(config-if)#interface FastEthernet2
ROUTER(config-if)#!
ROUTER(config-if)#interface FastEthernet3
ROUTER(config-if)#!
ROUTER(config-if)#interface GigabitEthernet0
ROUTER(config-if)# encapsulation dot1Q 1 native
% Invalid input detected at '^' marker.
ROUTER(config-if)# ip address 192.168.1.1 255.255.255.0
% IP addresses may not be configured on L2 links.
ROUTER(config-if)# ip nat inside
ROUTER(config-if)# ip virtual-reassembly
ROUTER(config-if)# ip tcp adjust-mss 1350
ROUTER(config-if)#!
ROUTER(config-if)#interface GigabitEthernet1
ROUTER(config-if)# description WAN-INTERFACE
ROUTER(config-if)# ip address dhcp
ROUTER(config-if)# ip nat outside
ROUTER(config-if)# ip tcp adjust-mss 1452
ROUTER(config-if)# duplex auto
ROUTER(config-if)# speed auto
ROUTER(config-if)# pppoe enable group global
ROUTER(config-if)# pppoe-client dial-pool-number 1
ROUTER(config-if)# no routing dynamic
ROUTER(config-if)#!
ROUTER(config-if)#interface Dialer1
ROUTER(config-if)# ip address negotiated
ROUTER(config-if)# no ip unreachables
ROUTER(config-if)# ip mtu 1492
ROUTER(config-if)# encapsulation ppp
ROUTER(config-if)# dialer pool 1
ROUTER(config-if)# dialer-group 1
ROUTER(config-if)# no cdp enable
ROUTER(config-if)# ppp authentication chap pap callin
ROUTER(config-if)# ppp chap hostname bthomehub@btbroadband.com
ROUTER(config-if)# ppp chap password 0 bthomehub@btbroadband.com
ROUTER(config-if)#$b@btbroadband.com password 0 bthomehub@btbroadband.com
ROUTER(config-if)# ppp ipcp dns request
ROUTER(config-if)#
ROUTER(config-if)#
ROUTER(config-if)#
ROUTER(config-if)#
ROUTER(config-if)#
ROUTER(config-if)#
ROUTER(config-if)#
ROUTER(config-if)#exit
ROUTER(config)#exit
ROUTER#reloaf
*Feb  5 21:48:20.947: %SYS-5-CONFIG_I: Configured from console by console
Translating "reloaf"...domain server (205.171.3.65)
% Bad IP address or host name
% Unknown command or computer name, or unable to find computer address
ROUTER#
ROUTER#
ROUTER#
ROUTER#reload
System configuration has been modified. Save? [yes/no]:
% Please answer 'yes' or 'no'.
System configuration has been modified. Save? [yes/no]: y
Building configuration...
[OK]
Proceed with reload? [confirm]
*Feb  5 21:48:53.699: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
*Feb  5 21:48:58.379: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Feb  5 21:48:59.379: %LINEPROTO-5-UPDOWN: L
System Bootstrap, Version 15.1(4r)M2, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2011 by cisco Systems, Inc.
C860VAE advanced k9 platform with 256 MB of main memory
Booting flash:/c860vae-advsecurityk9-mz.155-3.M1.bin
boot: Launch entrypt: 0x80800000
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################ [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C860 Software (C860VAE-ADVSECURITYK9-M), Version 15.5(3)M1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 16-Nov-15 19:14 by prod_rel_team
flashfs[6]: 2 files, 1 directories
flashfs[6]: 0 orphaned files, 0 orphaned directories
flashfs[6]: Total bytes: 55351296
flashfs[6]: Bytes used: 41273344
flashfs[6]: Bytes available: 14077952
flashfs[6]: flashfs fsck took 1 seconds.
flashfs[6]: Initialization complete.
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco 867VAE-K9 (revision 0.3) with 234496K/26624K bytes of memory.
Processor board ID GMK1224019J
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
255K bytes of non-volatile configuration memory.
57344K bytes system flash allocated
SETUP: new interface NVI0 placed in "shutdown" state
Press RETURN to get started!
*Feb  5 21:50:49.627: PIM: BFD initialization failed
*Feb  5 21:50:51.987: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
*Feb  5 21:50:51.987: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
*Feb  5 21:50:59.891: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Feb  5 21:50:59.891: %LINK-3-UPDOWN: Interface Ethernet0, changed state to down
*Feb  5 21:50:59.891: %LINK-3-UPDOWN: Interface ATM0, changed state to down
*Feb  5 21:50:59.891: %LINK-3-UPDOWN: Interface GigabitEthernet1, changed state to down
*Feb  5 21:50:59.891: %LINEPROTO-5-UPDOWN: Line protocol on Interface Onboard VPN, changed state to up
*Feb  5 21:51:00.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Feb  5 21:51:01.511: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
*Feb  5 21:51:01.511: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
*Feb  5 21:51:01.511: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Feb  5 21:51:04.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to up
*Feb  5 21:51:06.511: %CONTROLLER-5-UPDOWN: Controller VDSL 0, changed state to administratively down
*Feb  5 21:51:07.259: %SYS-5-CONFIG_I: Configured from memory by console
*Feb  5 21:51:07.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
*Feb  5 21:51:07.615: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
*Feb  5 21:51:07.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to down
*Feb  5 21:51:08.691: %LINK-5-CHANGED: Interface ATM0, changed state to administratively down
*Feb  5 21:51:08.691: %LINK-5-CHANGED: Interface Ethernet0, changed state to administratively down
*Feb  5 21:51:08.691: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Feb  5 21:51:09.491: %LINK-5-CHANGED: Interface NVI0, changed state to administratively down
*Feb  5 21:51:09.491: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
*Feb  5 21:51:09.491: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to down
*Feb  5 21:51:09.491: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to down
*Feb  5 21:51:09.491: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to down
*Feb  5 21:51:09.491: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Feb  5 21:51:10.567: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Feb  5 21:51:10.567: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to down
*Feb  5 21:51:10.567: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed state to down
*Feb  5 21:51:10.567: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed state to down
*Feb  5 21:51:10.567: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Feb  5 21:51:12.555: %SYS-5-RESTART: System restarted --
*Feb  5 21:51:13.331: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Feb  5 21:51:13.547: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Feb  5 21:51:14.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Feb  5 21:51:16.527: %SYS-6-BOOTTIME: Time taken to reboot after reload =  146 seconds
*Feb  5 21:51:41.915: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
ROUTER>
ROUTER>ping 192.168.1.2
% Unrecognized host or address, or protocol not running.
ROUTER>sh run
ROUTER>en
ROUTER#sh run
Current configuration : 2031 bytes
version 15.5
no service pad
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
wan mode ethernet
ip cef
no ipv6 cef
controller VDSL 0
 shutdown
interface Loopback0
 no ip address
interface ATM0
 no ip address
 shutdown
interface Ethernet0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 shutdown
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip address dhcp
 ip mtu 1492
 ip nat outside
 ip virtual-reassembly in
 shutdown
 duplex auto
 speed auto
 no routing dynamic
interface Vlan1
 description LAN-facing interface
 no ip address
 ip nat inside
interface Dialer1
 no ip unreachables
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp pap sent-username bthomehub@btbroadband.com password 0 bthomehub@btbroadband.com
 no cdp enable
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 10 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
dialer-list 1 protocol ip permit
mac-address-table aging-time 10
line con 0
 no modem enable
line aux 0
line vty 0 4
 password PASSWORD
 login
 transport input all
scheduler allocate 60000 1000
end
ROUTER#
*Feb  5 21:53:54.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Feb  5 21:53:54.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Feb  5 21:53:55.331: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
ROUTER#
pippincp
Message 7 of 18
Your router is not configuered correctly.
Post the configuration pages rather than the logs.
PAPADELTA
Message 8 of 18
Hi pippincp,
this is my config
no service pad
hostname ROUTER
boot-start-marker
boot-end-marker
no enable secret
no enable password
no aaa new-model
wan mode ethernet
ip cef
no ipv6 cef
controller VDSL 0
shutdown
interface Loopback0
no ip address
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no ip address
no ip address
no ip address
no ip address
 ip nat inside
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 no routing dynamic
interface Dialer1
 no ip unreachables
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 no cdp enable
PAPADELTA
Message 9 of 18
And this is the other one :
Current configuration : 2041 bytes
! Last configuration change at 02:17:41 UTC Sat Feb 27 2016
version 15.2
no service pad
hostname mrciscorouter
boot-start-marker
boot-end-marker
enable secret xxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxxx
no aaa new-model
wan mode ethernet
ip cef
no ipv6 cef
controller VDSL 0
shutdown
interface Loopback0
no ip address
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip mtu 1492
duplex auto
speed auto
interface Vlan1
ip address 192.x.x x.x.x.x
ip nat inside
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxxx
ppp ipcp dns x.x.x.x x.x.x.x accept
ppp ipcp route default
no cdp enable
no ip http server
ip dns server
access-list 10 permit 192.x.x.x x.x.x.x
mac-address-table aging-time 15
snmp-server community xxxxxxxxxxxxxxxxx
line con 0
no modem enable
line aux 0
line vty 0 4
password xxxxxxxxxxxxxxx
login
transport input all
end
licquorice
Message 10 of 18
Did you set VLAN to 101?
