papafixit
Message 1 of 5
BT infinity
Just had BT infinity installed with Hub5. I run my TV's in other rooms with a wireless sender and receiver and now I am gettiing interferance on the TVs every 2-3 seconds. As the only thing that has changed is the new broadband I switched off the hub and disconnected the phone and bb cables at the phone socket, however still getting the wireless tv interferance. I am wondering if infinity is c ausing some sort of wireless interferance to the home. Anyone else had same problems / fixed it. I changed the wireless signal on the tv sender as I have 4 options and it does it on all 4 chanels.
4 REPLIES 4
Message 2 of 5
Re: BT infinity
infinity will not cause that problem however wireless senders are a known cause of problems
Message 3 of 5
Re: BT infinity
have you tried turning of smart wirless and selecting your own channels in the HH5  I would also split the 2.4 and 5ghz networks by say adding a 5 to the 5ghz network and then giving then the same password.  possible you tv cannot conenct at 5ghz.  many devices don't like to 2 channel combined
papafixit
Message 4 of 5
Re: BT infinity
Thank you, as I have just got the HH5 not played about with any settings, how do you go about doing that?
Message 5 of 5
Re: BT infinity
To give the 2.4Ghz and 5Ghz frequencies different SSids. Just add a 5 to the end of the 5Ghz SSid so you know which is which. Check the 5 GHz Sync with 2.4 GHz: is set to NO.
You'll need to connect your other devices that can use both frequencies to both SSids if you want them to be able to use either/both frequencies.
See this link
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
To select a fixed wireless channel see Link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/14094/~/how-do-i-change-the-wireless-channel-on-my-bt...
Also try turning off "Smart Set Up" on the homehub, it can cause problems with some wireless devices. See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
